Digital LED temp readout and alarm installed
woodmiser
390
Garnet Valley, PA
Using an Auber Instruments PID controller ($36) with a Model: TC-K6 thermocouple ($6.85), a project box ($15.50) and an light/alarm ($8.22) Total ($66.57) I came up with a nice electronic way to monitor temps and notify me if I go over a set temp. I drilled an tapped a 1/4-20 hole in the top of the stove for the thermocouple. The controller runs on 115v AC so I tied it into the fan power line. The light/buzzer is also 115V so it ties directly into the controller. The directions show how to program it to go off at your setting.
This is installed on a Clydesdale insert.
http://www.auberins.com/index.php?main_page=product_info&cPath=1&products_id=14
http://www.auberins.com/index.php?main_page=product_info&cPath=20_3&products_id=2
http://www.auberins.com/index.php?main_page=product_info&cPath=7&products_id=24
http://www.auberins.com/index.php?main_page=product_info&cPath=7&products_id=221
Sweet, I have always wondered why you dont see more people with inserts doing that.
Just out of curiousity is that measuring stovetop temps or the flue temp?
Not a bad idea. I like your thinking. For the price, why not? Better safe than sorry.
I didn't read all the specifics on the temp meter but can you adjust the temp for when the alarm goes off?
That is slick. I have had the PID for years now but couldn't convince myself that a thermocouple that wasn't surface mounted would give me the right reading. And those mag thermocouples is kinda pricey.
Yes to whatever you want. Alarm1 High, Alarm1 Low, Alarm2 High, Alarm2 Low. You can set these parameters to any temp you choose.
It also has another output to run external circuits such as heater controls.
I'm going to have to install a set screw into the thermocouple hole to limit the reading. The thermocouple tip right now is directly exposed to the firebox so my readings on the high side are 150-200 deg hotter than the IR'd surface. I also have a piece of foil-faced ceramic insulation wrapped around about 2" of the TC wire to protect it from stovetop temps over 500F. That's all the TC wire is rated for.
Very nice . . . and not too crazy of a price either. Thanks for posting.
Best way depends on exactly what you want to monitor. For stovetop a magnet mounted thermocouple would be best but they are over $50. That's why I chose the screw in style.
ACE Hardware has'em. I have thought about doing that too.
I have had 2 PID controllers on my stove for a couple of years now. One thermocouple is inserted in the stove pipe and one is held down to the stove top. I initially tried several magnets but they would demagnetize permanently by the heat. I found some at Grainger that were rated for high heat but they are pricey. Treacheous, That magnet you linked to is the same kind (Alnico) that I have and it has worked good and kept it's magnatism.
How much are you talking Bart?
There's some stuff we use on airplanes to bond oil pan heaters to the oil pan. It's like a super conductive JB weld. I'm not sure how high a temp it will handle but I can check. Also, its a bit pricey too. I forget how much but if you're interested I can look into it. Just PM me.
Shoot. I just read further down. $50.00 for a magnet mount. My idea might not be much cheaper. Also a normal magnet won't work. They have to be rare earth or something special. If you heat a normal one up it loses it's magnetism.
Nice job on that temp control! E-bay has some great deals on temp controls including yours and some are around 20 bucks with free shipping!
Ray
When I'm satisfied with my thermocouple readings I'll take a few pictures of the TC install. Like I said earlier, my TC is exposed to the firebox so my readings are 150-200 deg higher than actual stove top. The alarm works well. Woke me up just after I fell asleep when it hit 700. Actual stove top was around 525.
Nice. I've been wanting to do this to monitor my internal flue temps on my single wall pipe but I can't figure out which type of thermocouple to use. I guess I would need one with a 3" probe to reach the center of my 6" pipe and it would have to be rated for over 1000 degrees. Any ideas?
Only 2" but rated to 1400'F
Ooooooh. I wonder if I can rig one up to replace the condar catalyst probe thermometer. It would nice to get a warning beep before an overfire.
woodmiser said:
K types go over 2000 F. Just watch out for the rating of the connecting wire which is usually 500F. You should be fine with 500 since you won't see those temps out in the air away from the pipe.
Here's a 6" one for under $20
http://www.auberins.com/index.php?main_page=product_info&cPath=20_3&products_id=22
I'm confused, are all K types good for over 2000 or are they talking about the max wire temps? This one for a smoker has a 4" probe but gives two different temp ratings, one for the probe and one for the wire. I guess I could get a longer 6" probe and not insert it all the way in but would that effect the temps? Where do these things take their readings from, the tip or the whole probe?
http://www.auberins.com/index.php?main_page=product_info&cPath=20_3&products_id=101
Readings are at the tip. You don't need it to go into the middle. A 2" one would work. Yes most K's are good for 2000F
