I ran across this artical thought some others would enjoy.
http://www.backwoodshome.com/articles2/fluckiger132.html
WoodNStuff said:The directions in this article explain the method in concise detail. I like the pole in the center marked with a line at the 80% of total height. When you can see the line on the rod, your wood is seasoned. Also, like the wood piled vertically in the center to create a chimney effect to aid drying.
http://www.thechimneysweep.ca/6seasoningwood.html
GolfandWoodNut said:WoodNStuff said:The directions in this article explain the method in concise detail. I like the pole in the center marked with a line at the 80% of total height. When you can see the line on the rod, your wood is seasoned. Also, like the wood piled vertically in the center to create a chimney effect to aid drying.
Hate to argue but stacking vertically is the biggest waste of time. Most people like to just throw the wood into the middle on an 8 foot diameter one. It is nice of odd size pieces. Stacking vertically will drive you nuts trying to keep the wood from falling over. The chimney effect is negliable, I would say no existent. Also if you give the wood a year or two is all you need, you will see it shrink. If you want to see the moisture content, get a moisture meter.
LLigetfa said:Now, when you want to talk perfection, take a look at this. http://soede.net/soede/index.php?option=com_content&task=view&id=151&Itemid=9
I know what you mean, I even decorated my HH with Xmass lights the one year. But once you start tearing it down, they look bad and it gets easier. The one thing I did do with a large one was tear half of it down and then rebuild that half the next year to keep it going. The eight footers I do not feel are near as neat as a 10 footer so I do not expect I will have the same desires. Not many people build the 10 footers. If you look at my avatar you will see how small I am in the picture and I am 6'2"NH_Wood said:I'm worried that if I built one of these, and it came out really nice, I wouldn't ever be able to tear it apart to burn the wood! Cheers!
Trailmaker, that seems like alot of extra work to do the inside first. On the 8 foot diameter ones I just throw the wood to the inside after building the outside, and before putting the roof on. I agree to keep the wood sloped inwards for strength, but I see not benefit from tapering the whole stack. None the less good job.trailmaker said:Thanks Jake, that's a beautiful spot and the only place on my property that's really suitable for drying wood. I think the organic look of the HH compliments the scenery.
