Paint wiping off
smmm
75
Ohio
Okay.... Fires are burning nicely. Glass is staying clean. No smoke in the room. Odor of paint curing is about gone. Thanks to you guys I have solved these problems. Another question that has presented itself. We were out of town for a couple days and when we got back I decided to clean up a little before I started another fire. Thing I noticed is that when I wiped off the stove with a dry cloth, there is some (what looks like paint residue) on the rag. When I wet the rag and wipe the stove, the rag has a deep black residue on it. Doesn't matter where I wipe, this happens. Even areas that are not subject to any smoke whatsoever. One spot I rubbed a few times is a noticeable difference. Seems lighter and now has more of a matte finish...
Any ideas?
I noticed this with my stove too. One spot I cleaned the paint off with out realizing it. I guess its the nature of the paint. Hope some pros will help out here.
Mine did this to when I wiped with a wet rag. Thing is that it only did it in the areas where I used Stove Bright paint. Where I used Krylon it didn't do it. I repainted the whole thing with Krylon and haven't had an issue.
I had this happen when I have used high temp spray on paint. I switched to using the brush on and find it has been much more durable.
pen
Okay... Thanks for the replies. You would think Buck Stove's or any manufacturer would put a message on there about this. I would have never thought that wiping them down would do this. Actually being a beginner at this, I would have thought the opposite. I would have thought that there would be no way to scrub the paint off after it baked in.?
Oh, forgot to ask.... Does anyone know of q quick touch up solution as opposed to repainting the whole stove. I would rather wait a few years before that.
Wonder if you can use that after painting? I painted mine this past fall and got a) the black powdery residue and b) a large white spot on top of the stove (and also at the top of the door nr the airwash vent holes).
I used that identical polish that a friend loaned me and I ran into the same problem with the flakey film rubbing off. Dealer told me that its really for enamel finishes. I get less residue as time goes by. I say let it be.
I used a rust-oleum oil-based enamel paint 6+ years ago, brushed on, and was happy. It needed a refresh this year, and I used a rust-oleum spray. It also looked great, but suddenly one evening it had a lighter gray tone on top of the stove, and had the powdery residue. Now every time I brush any stray chips off the top I have to go wash the residue off my hands. I guess I'll take it back outside next spring and try again with the brush-on variety.
