drizler
Call me crazy but I just don't see all these headaches burning corn and as I have said I burn both. Corn can get wet and it dries out and burns ok, pellets will give you a bag of sawdust. I know as Ihave one right here now that I toss some in to help start the thing sometimes. As for rodents I leave mine sitting in the garage with the door open most of the time or in the back of the pickup, I never saw a mous around but I do have a few cats, not that that stops them. I live in a hay field so there are plenty around. Also in my experience I find that mice will go after the pellets rather than the corn. Again its not such a big deal as if they ate their fill all winter how much would it represent? You should have Decon out no matter where you live or what you heat with anyways to keep them from causing trouble with your wiring. Lastly if you think you can keep them out by sealing up the house my hat is off to you cause it's not goint to happen. I do clean the stove about once a month in the busy burn season and clean out in the back of the flue area where it builds up. No big deal and from what I heaf that is something of a Countryside issue. If you waant animal issues try racoons. They do make a mess but again will do it to your garbabe in as quick a time and make just as much mess. I just exported 7 of them in the last week to a big forrested areax a few miles away.
I use standard pellet vent with mine all $200 of it an in 2 years its still in good shape. To change that out is all of a half hour's work tops so its a minor consideration. About the most corrosion I have is some light staining from 2 years useage. Mine does call for simple p vent per the manual. Mine will only wirk with a White Rogers setback stat as I found out the hard way. Another thing with mine is that if it goes out you have to relight it which I don't mind. Shutdown is nice yea but most of the heating season that low setting is needed to keep from freezing anyways so just let it run like a diesel truck. To start mine I found the best way is a fist full of pellets and a turbo brazing torch ( propane). That fires it up quick with no gels or other expensive hassles. It costs me about 1 handheld bottle of propane for the season which is peanuts
FWIW I see that they are selling those countrysides via internet sales again which they haven't in some time. Check the ads at the top of the page on the iburncorn forum section, I think its Zooger or something like that. Sells for $2100 and they were going for $2600 aroound here last year. Not hard to install either I might add. Anyways got to run to an appointment. Good luck, don't wait till Fall or get out your wallet.
