Hello
Going through this Harman with a fine tooth comb. I replaced the circuit board with a new one so it works like the new stoves. However I found a long standing issue on the older Harmans where I have not seen an explanation and the sure fix.
The flames were hitting the brick backing and creating a big round black charcoal spot on the back of the iron brick backing!
Thanks to this thread I had a very good clue!
https://www.hearth.com/talk/threads/harman-advance-flame-guide-design-change.83130/
I removed the old Flame Guide and it did not have the air port notches. The flames did not blow out away from the back firewall.
I had a new flame guide with the notches and put it in the stove and TaDah!
The flames no longer hit the back and it works fine.
It is possible that putting in the new circuit board made this problem more apparent, but that certainly explains why the air ports were added!
The Advance and Acentra has the notches because the fire is close to the back. The P-Series does not have or need these air ports!
Pic 1 - Large Fire hitting back
Pic 2 - Small fire shows black back
Pic 3 - Black back no fire
Pic 4 - New Harman Flame Guide
Pic 5 - Old Harman Flame Guide Bottom Vs New Harman Flame Guide Bottom
Pic 6 - Old Harman Flame Guide Top Vs New Harman Flame Guide Top
Pic 7 - New Flame Guide Vs Old Flame Guide
Pic 8 - Flame with New Flame Guide not hitting back and working fine!
