2000 Avalon Olympic 1190 cracks in secondary air chamber repair question
bushman
Burning Hunk
Dec 28, 2014
156
Northern Michigan
Yesterday I traded an old Kawasaki 3 wheeler and a Ruger 10/22 for a used Avalon Olympic with a pedestal and blower. The stove is in very good shape other than its was missing the secondary air tubes, Y bracket and it has a few cracks in the T shaped area of the secondary air manifold and corners.
I researched a few posts about Lopi Libertys having the same problems along with some other Travis steel stoves. Was there ever a repair kit for this or could my welder fix this more efficiently?
Some posts from pro welders say not to weld the stress crack but, what would be the fix, to weld plates over top of the cracked areas? Has anyone bought the repair kit from Travis?
Here are some pictures.
Depending on your skill level at welding, I would weld patch plates over the cracks. All that steel does is conduct air and hold your firebrick in place. It's not like a crack on the exterior of the firebox.
Yesterday I contacted a fellow from Travis Industries and was informed they did not have pre made kit's for covering the cracked areas.
Tonight I will try to get the stove to the welding shop and see what they come up with, should be a simple job.
My concern is having raging secondary burns from these cracks instead of the stainless tubes and it just doesn't look nice.
