My first pellet stove!
Bought a King / Ashley 5500M by United States Stove Company. I am doing the vent and the air intake myself as I have done this to several wood stoves. I KNOW that there are differences, and so the reason for this thread! Note that my house is two story with a nice hearth / fireplace and a 24 foot masonry chimney that runs up both stories. It is 10.5 inches by 10.5 inches on the inside. This results in 18.375 cubic feet of airspace total through the whole chimney. I am not so concerned about plumbing the air intake as I have a nice large ash drop in the floor inside the fireplace......my main concern is the vent exhaust! And I DO want to use my hearth, fireplace, chimney set up ....it is the BEST place to do it!
FIRST QUESTION:
I have read several articles and documents concerning vent exhaust and air intake for a pellet stove including the manual that came with this stove I purchased. Most say to use 4 inch pipe as my house is above 2500 feet (more like 6800 feet..!!) and my vertical run will be more than 12 feet.....most recommend using 4 inch pipe......OK....but all the stoves come pretty standard with a 3 inch exhaust port.....hhhmmm!....restricted already! Another article said to use a "chimney liner" (looked like an oversized pipe...6 inch?....8 inch?).....I had a friend who has pellet stoves say he would try just sealing a 4 inch exhaust at the bottom and then sealing a 4 inch or 6 inch chimney cap (with weather hardware) at the top. But NONE seem to address using a two story masonry chimney like I have...! I KNOW someone has done it and I want to benefit from their experience....
So the three options (so far) seem to be:
1. Use 4 inch pipe all the way, seal at the bottom and the top.
2. Use a "chimney liner"...which I think is just 6 inch or 8 inch pipe...again I would seal at bottom and top
3. Seal at bottom and top (4 inch out of stove, 6 inch for chimney cap) and just use the masonry chimney all the way (22 feet to 24 feet)
I know this is probably a physics problem, and I look at it two ways........the BARE masonry chimney would have the least resistance to air flow as it is much larger than pipes......but then on the other hand you need to "push" against all the air that is sitting in the chimney......??.....so which is it? Will I get the best draft just using the bare chimney, or with pipe all the way?
SECOND QUESTION:
Most of the articles recommend the stainless steel / aluminum pipe that is rated and recommended for pellet stoves......but my Lord! What a price! Seems like you cannot touch a piece of pellet stove pipe for under $40 - $50 bucks! If I run this pipe all 24 feet I will be spending many many hundreds!
I have a friend who said he used just regular double wall stove pipe (galvanized?) to vent his pellet stove, and says he just makes sure he keeps it clean and has had no problem for years..!
I also know that they recommend a clean out "Tee" right out of the stove. This makes sense.
So I am asking WHY is this expensive pipe recommended when it seems regular stove pipe would work if you keep it clean? Seems a pellet exhaust is no where near the high temperatures of a wood burner...??? I know there is ash, but you just make your vents so they are easy to clean...??
Can I get away with using the pellet stove pipe at the bottom and using regular stove pipe up the 24 feet?........
THIRD QUESTION:
Has anybody already done this? And how did you successfully do it? Cleaning tips?
Thanks for reading!
Greg
FIRST QUESTION:
SECOND QUESTION:
THIRD QUESTION:
Thanks for reading!
Greg
