    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. CTguy9230 Feeling the Heat
    Northwest CT
    ok pellet stove guru's, i need to replace the window
    gasket on my stove, do i need to order it from Englander, or
    is there a generic replacement i can use ????
    thanks !
    #1
    Helpful Sponsor Ads!
  2. ScottyDaug Member
    Maine
    You can order it from Englander, or as long as you make sure the size matches up, any good hardware store carries stove window gasket. I purchased my last window gasket for my USSC at the local hardware. Typically the hardware store will be much less expensive.
  3. imacman Minister of Fire
    If you can find 1" wide gasket that has adhesive on one side, and is the right length, it should work. The gasket Englander sells is dark grey and 7' long, I think.
  4. CTguy9230 Feeling the Heat
    Northwest CT
    ok guys thanks.....will try a hardware store tomorrow
