from stone cold, with a few old black coals to help. Had the ash-pan door cracked open (cheating, in my book) and it didn't take long to torch up. Doubtful it's good for the stove's health..but curiosity got the better of me
You are right! Opening the ash pan to boost the fire voids the warranty. The worst time to do this is when the stove is cold. Since the cast gets super heated in one spot and can not come up to temp evenly. In an F-3CB I have never seen the base plate crack, but there is a first time for every thing. Be careful with this habit. Many folks on here love the super cedar fire starters. They bring the stove up to temp fast and are safer to use then the ash pan.
yeah i won't do it again, simple "wonderment" is my only explanation LOL. Just to clarify.. i didn't run ash door open to 600*, closed it off after maybe 10 min (guessing maybe 400*? - but i didn't actually check it at that point). I wonder tho - how would the manufacturer know to void the warranty (assuming the user didn't mention the ash door method...)
Most of the time that is true. And if the base plate cracks. Those would really be the only 2 times you would need to use the warranty. If you try and submit for either the light bulb goes on for the dealers. The only other thing i have seen happen is the baffles warp from time to time, but its rare.
The good news is that in 30-60 minutes with experience you should be able to bring the stove up to temp . . . maybe not so fast or quite so hot . . . but it will be hot enough to start throwing off heat . . . and you will not risk damaging the stove by using the ash pan . . . which by now you realize is not a good idea.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
