2nd story Hot!
smokinj
15,980
Anderson, Indiana
sould you push cool air to the 2nd story or pull hot air down to the 1st story?
Yes, essentially that is what a ceiling fan running in reverse does. But is this due to heat from a wood furnace or wood stove? If it's from a wood furnace, the ducting is imbalanced or improperly configured.
There is a catheral ceiling where the heat loves to go i have a ceiling fan there,i can create a covection just trying to see witch diretion to go? the 2 nd story is runnin between 8-10 degrees warmer(two fans)one in the cethral and one in the stair well
Try running the fan in the cathedral ceiling in reverse (up) and the hallway fan normal (blowing down).
How are these spaces being heated? Stove, forced air, radiators?
force gas used very little and force wood furance used 95 percent of the time
Sounds like there may be too much warm air feeding upstairs or too much fuel in the firebox for fall burning.
i"ll try all three segestion thank you!
