Hi, I am planning to buy a pellet stove for this season and have talked to a reputable dealer in my area. He gave me some advice that I would like to confirm is good advice.....I appreciate your comments!
1. Radiant heat - The suggestion was that if I like the radiant warmth that you would get from a fireplace or wood stove (which I do) to consider a heavier cast iron type pellet stove instead of a lighter steel stove. He said that in the lighter stove you would get warm air from the output, but not much radiant heat. Is this a valid consideration (and true)?
2. Venting - He suggested that an outside air kit was not that important, and (if I understood him correctly) that the stove would actually burn better when using inside air for combustion. This does not seem to make sense to me, I always understood that burning house air could create drafts (I understand that a pellet stove does not burn as big of a fire as say a fireplace, but wouldn't that theory still hold??) . Also as I continue to make other energy improvements by insulating (making the house tighter) wouldn't an outside air kit make sense?
3. Efficiency - My own question here (nothing to report from my dealer).....is there a standards on measuring efficiency of stoves and is there a source of this information? As I peruse the literature from different manufacturers, this info seems to be inconsistent or absent. Again, is this a major consideration whan making a purchase?
Thanks for any advice, I hope to make my decision within a week or so. Rick
