Guys, got a new 33 RS chain and it says that the angle is to be sharpened at 30 degrees, but it looks like the teeth are at 35 degrees. Has anyone seen this? Sharpened at 30 degrees today and it looks like I'm changing the angle on the tooth....
As a note for others, make sure to align the filing guide angle with the bar as the angle reference, I found that aligning it with the chain can made it appear that the angle should be different, ie. 35 vs 30 degrees.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
