    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. kgbela New Member
    Taunton Massachusetts
    Hi guy's, Could somebody please tell me how important it is to use sealant on the joints of this 4" pellet stove pipe. I picked up a knew harman xxv model and i am planning to hook this stove up in the morning. Thanks for the advice.
    #1
    Helpful Sponsor Ads!
  2. hearthtools Super Moderator
    I dont see the need to seal every joint if you use Duravent with the twist lock and put 3 screw in every joint.
    We only RTV the Connection to the stove and the slip connection.
    <snip from Dura vent instructions>http://www.duravent.com/docs/instruct/L502_aug05.pdf
    8. Sections of pipe are connected to each other by pushing them firmly together and
    twisting. Screws are not required. If however, screws are desired, use 1/4"-long
    sheet metal screws. Under no circumstances, penetrate the inner liner with screws.
    9. RTV Sealant may be required at all vent joints. Refer to Appliance manufacturer.
    </end of snip>
  3. MountainStoveGuy New Member
    I feel thats it is important to seal the joints, what i have observed is ash leaking around the seams in the pipe in the show room. this would not happen if i sealed them up. Also, in a direct rear vent installation, smoke will leak from any joint that is not sealed. If the pipe spec says check the manufactures spec, then check the manufacturs spec, my manufacture specs out sealing the joints. Just a question, why would you not seal it? the only reason is that its hard to get apart. any other reason not to seal it? BTW i never rtv it to the stove, i use tape there.
  4. moog5 New Member
    Shingle Springs, CA
    Congrat's on the xxv, I too own one. You are going to love it.
    I would seal pellet pipe for peace of mind even though you probably don't need to. I used the 6" stove adapter so I never had to make the decision.
    12 years ago I installed my previous pellet stove using the duravent pipe (twist on type). When I sold it last year, I gave the old duravent pellet pipe to the person who bought the stove (~15' of it). Before he took it, we tried with all our might to break the joints, but no luck at all. Probably because I used the sealant quite liberally, I never thought about the time when I would have to take it apart. The only way I could pull it out was to twist hard enought to break one of the adustable elbows. The person who bought my old stove took the straight sections thinking that he might be able to salvage them by using tin snips to cut the elbows out.
  5. hearthtools Super Moderator
    A agree with seal if you have to but in over 900 pellet stoves that I have personaly installed I dont see many Streight lengths that leak soot unless there is a problem with venting the leaks are at sometimes the T, elbos and slips.
    I dont have a problem with Leaks in Direct vent installs because I will not install a pellet stove Direct vent.
    It is next to imposible to Take Duravent pipe apart after RTV.
  6. saichele Minister of Fire
    Aren't all pellet stoves direct vent? Or do some of them 'draft' like wood stoves?
    Steve
  7. MountainStoveGuy New Member
    No, direct vent in this conversation is described as going strait out the back of tha appliance with no rise. What Rod is saying, and i complety agree with, is that when you go verticle there is no need to RTV the pipe, there is enough natural draw in that installation that ash will not work its way out the seams. Ash will work its way out the seams in a horzontal install because there is enough backpressure. Unfortunalty most people install them strait out the back, they work that way, but as stated earlier, you have to seal the pipe, and you have to live with a smokey house during poweroutage. The next best thing would be to go up severl feet then out, in that install i would still seal the pipe, but in a power outage your stove will not belch smoke everwhere. The only install that i would not seal the pipe is a complete verticle install.
  8. hearthtools Super Moderator
    Yes you can Direct vent straight out with no vertical rise but like the very wise MtStove guy said above is that you WILL get smoke into the house. But what he did not say was your WILL get Smoke and soot on the Side of the house and ground if you direct vent a pellet stove.
    Most all pellet stove manufactures show in the manual direct vent installations. But most also say recommended to have at least 5 feet of vertical rise in vent run to prevent smoke spillage in the home during power outage.
    why not to direct vent
    http://www.hearthtools.com/install/DONOTDIRCTVENT.jpg
    Problem fix
    http://www.hearthtools.com/install/nodirectvent2.jpg
  9. HarryBack New Member
    Western Massachusetts
    ok- putting RTV on the joints will most likely ensure you wont get them undone....ever again.....but they will be sealed. We use high temperature silicone tape to tape our joints...all of them. Its removeable, reuseable, and doesnt fall off like that foil tape I sometimes see. I see no good reason not to seal all the joints....the silicone tape is fairly cheap, and could ensure less callbacks. As a correlary, we ALWAYS RTV the first section to the stove.
  10. hearthtools Super Moderator
    what kind of tape is that.
    do you have a link to info and where you get it.
    I dont like foil back tape because it never sticks to SS
    Btw
    Long time no Forum with eachother.
  11. HarryBack New Member
    its a black silicone tape, roughly 3/4" wide.....ill get the TrueValue number at work tomorrow....this same number should be good at all trueValue hardare stores even in your local area.
    nice to see ya around and about, Rod!
  12. MountainStoveGuy New Member
    What is its temp rating? I havent heard of this stuff, it sounds like the right tool for the job.
    Also, do you use the simpson pipe adapter? And if so, why do you RTV it instead of taping it? I know the foil tape doest stick the best, but a few wraps around it and its tight, then at least you can get the stove off the flue if you need too.
  13. hearthtools Super Moderator
    Boost to this thread
    I got to play with the NEW ICC pellet vent
    Great looking stuff.
    has a built in silicone gasket.
    No twist lock
    Clean joints.
    Will be a litlle bit more money but will install much faster.
    For all you people that like to direct vent they have a snorkle cap
  14. Metal Minister of Fire
    I take it you mean Excel when you say ICC, correct? Their website doesn't give any info on it, the link just goes to their HT product.
  15. hearthtools Super Moderator
  16. SoCal65 New Member
  17. stoveguy2esw Minister of Fire
    madison hgts. va
    [quote
    Steve[/quote]
    actually , we built a pellet stove that was not a direct vent up through about 1995. it was a 6" top vent that hooked to a woodstove chimney , used the same rules for draft that would apply for a woodstove. worked quite well. it had a low velocity fan the actually blew air into the firepot from the intake side, and natural convective draft cleared the smoke. we still get calls from people asking if we will bring it back.
  18. staplebox Member
    Eastern CT
    This looks like a good place to get an answer without starting a new thread.
    I am (hopefully) installing my new Englander/Summers Heat 55-SHP10 tomorrow.
    I am looking for the best method to attach the Dura Vent pipe adapter to the stove's exhaust pipe. The adapter fits sort of snugly over the exhaust stub.
    I have read about :
    RTV (may never come off),
    screws (not much room on adapted sleeve and the exhaust stub looks like it needs to be pre-drilled- it's thick),
    silver tape (falls off),
    and silicone tape (havn't seen it but it doesn't sound to solid).
    I would like it not to leak and be able to take it apart someday.
    Thanks for the help.
  19. jtp10181 Minister of Fire
    Madison, WI
    You can use silicone caulk and still get it apart later if needed. Just don't go crazy with it. Use a small bead, just enough to seal it.
Thread Status:
