    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
4 way wedge
Post in 'The Gear' started by FireNewbie, Mar 11, 2010.
  1. FireNewbie Member
    Michigan
    Question: Does anyone know if the troybuilt 27 ton splitter can handle a 4way wedge? I was thinking of having a buddy weld one up, but wasn't sure if it had enough power for it. I guess what type of wood to be split would play a factor... Thanks.
    #1
    Helpful Sponsor Ads!
  2. kwikrp Feeling the Heat
    SE Mass
    I think it will have enough power, I have one but can not find a 4 way that will fit a troy bilt. If you find one that will fit please let me know i will buy one too !!
  3. iceman Minister of Fire
    [quote author="kwikrp" date="1268374536"]I think it will have enough power, I have one but can not find a 4 way that will fit a troy bilt. If you find one that will fit please let me know i will buy one too !![
    /quote]http://www.freewebs.com/logsplitter/
  4. webie Minister of Fire
    Wisconsin
    I am running a timberwolf Tw3hd , Its a 3point Pto splitter ( 22ton ) It came standard with a 4 way head , and I bought the optional 6 way head and use that quite a bit . I dont think I have ever used the splitter with out at least the 4 way head on . So I would think for sure your 27 ton would handle a 4 way head .
  5. LLigetfa Minister of Fire
    NW Ontario
    What I don't like about those Robert Collopy wedges on a moving wedge design is that they are angled top and bottom. This creates lift on the slide. They should be angled only on the top and straight on the bottom like a wood chisel.
  6. webie Minister of Fire
    Wisconsin
    I had to read this over like twice till I finally figured out what you were talking about , ( sorry a little solw I worked all night )
    The actual wedge for the the first split is fine as a V but LLigetfa is right the 4 way part should be flat or even at a slight taper up as similar to a wood chisel or your secondary splitting your splits will wedge tight .
    Since this is a custom shop I am sure he could probably do that with out a problem .
  7. mellow Minister of Fire
    Salisbury, MD
    I'm looking at getting this same wedge for my 27 ton, anyone get one and have a review? Saw someone on arboristsite that has one and likes it.
  8. smokinj Minister of Fire
    Anderson, Indiana
  9. mellow Minister of Fire
    Salisbury, MD
  10. smokinj Minister of Fire
    Anderson, Indiana
    There is a guy that makes them for troy built and had the adress at one point. I will look again. At one point I was going to buy it, but decided against it with the wood I get.
  11. smokinj Minister of Fire
    Anderson, Indiana
  12. mellow Minister of Fire
    Salisbury, MD
    Yep, that is why I said I am looking to get the same wedge :)
    Iceman posted the same link and why I mentioned arboristsite in my question.
    If anyone has this wedge I would sure love to hear more about how it runs on your splitter.
  13. mellow Minister of Fire
    Salisbury, MD
    smokinj likes this.
  14. mellow Minister of Fire
    Salisbury, MD
    Got mine ordered, will post a review of it when I get it later this month.
    smokinj likes this.
