50mph winds.....Flame on!!!!!
NordicSplitter Posted By NordicSplitter, Feb 24, 2012 at 11:11 PM
  1. NordicSplitter
    NordicSplitter
    Minister of Fire 2.
    NULL
    May 22, 2011
    541
    194
    Loc:
    Western,NY
    Lot of wind tonight in WNY......Have the damper at 2 and the Jotul is running like a blast furnace at the old steel plants...Wow!!!
  2. delp
    delp
    Member 2.
    NULL
    Jan 6, 2009
    186
    5
    Loc:
    pittsburgh, pa
    Holy draft from hell, batman!
    Same here in Pittsburgh, PA, unbelievable gusts of wind. Air inlet is as fully closed as closed can be on the 13NC, but the flames are just getting sucked up and out. Burn time, 3-4 hours, tops, on a full load...
  3. NordicSplitter
    NordicSplitter
    Minister of Fire 2.
    NULL
    May 22, 2011
    541
    194
    Loc:
    Western,NY
    Crazy I know. I usually load it back up around 9-9:30pm and call it a night. I guessing around 7:30-8pm tonight. Have my oldest toss some in around midnight.
  4. Wood Duck
    Wood Duck
    Minister of Fire 2.
    NULL
    Feb 26, 2009
    4,735
    822
    Loc:
    Central PA
    It is getting windy here too. Gusts are around 30 mph, or maybe a little higher in the last few minutes. My stove is not drafting much differently than normal. I plan to burn hot all weekend becuse it seems like a while since that has been needed.
  5. tcassavaugh
    tcassavaugh
    Minister of Fire 2.
    NULL
    Jan 10, 2010
    1,025
    146
    Loc:
    Southern Maryland
    winds came through here about 1530 this afternoon......started a fire in my little Jotul, no problems with the draft, thats for sure. i use my key/pipe damper to help keep things nice and slow. :)
    cass
  6. wkpoor
    wkpoor
    Minister of Fire 2.
    NULL
    Oct 30, 2008
    1,854
    82
    Loc:
    Amanda, OH
    I typically run the damper and primary full shut on a non windy day. Today I could have used 2 dampers and that may not have slowed er down.
  7. ScotO
    ScotO
    Guest 2.
    NULL
    she's howlin here right now, gusts around 30 to 40mph. will load 'er up with some good white oak a half hour before bedtime and shut the draft off. No damper on this rig....
  8. gmule
    gmule
    Feeling the Heat 2.
    NULL
    Feb 9, 2011
    452
    246
    Loc:
    Conifer Colorado
    We had those winds on Wednesday. I think they may have sucked some ash out along with the fire because it seemed like there was more room in the fire box in the morning.
  9. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    Gusting around 40 mph right now and supposed to continue for the next 12 hours. So far so good. Alittle sqirrely tho, with the trees around the house. Maybe some of the leaners will come down back in the woods.
  10. Oldhippie
    Oldhippie
    Minister of Fire 2.
    NULL
    Dec 18, 2011
    570
    259
    I just filled for the night and closed the damper, noticed still quite a lively fire with the draft pull, and it is 32'F, so not that cold. But the wind must act like a vacuum and pull a strong draft.
  11. Gark
    Gark
    Minister of Fire 2.
    NULL
    Jan 27, 2007
    808
    208
    Loc:
    SW Michigan
    Which direction the wind comes from here determines whether it cranks the stove. From the east, watch out! Tells us which outer wall is the leakiest... Any other direction... no difference.
  12. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    9 1/2 hrs since my last post, winds sustained at 20 to 30 mph with gusts up at 45 mph, temps got down to mid 20's last night with a wind chill in the upper teens to low 20's. Still had a strong bed of coals this morning, fire went right up, secondaries blazing. Be well
  13. GAMMA RAY
    GAMMA RAY
    Minister of Fire 2.
    NULL
    Jan 16, 2011
    1,970
    424
    Loc:
    PA.
    The weather lady said winds here up to 50 miles per hour today, that makes me a lil nervous with the big bad 30.
    I do have a pipe damper installed but have not had to use it...maybe today will be the first. :smirk:
  14. laynes69
    laynes69
    Minister of Fire 2.
    NULL
    Oct 2, 2006
    2,234
    196
    Loc:
    Ashland OH
    I have a manometer mounted to our flue pipe. When I was loading our furnace last night, the draft jumped from .05" to .30" with a heavy gust. I just closed the manual damper slightly and it tamed the draft where needed. I knew the wind could increase draft, but not that bad. Sounded like a jet coming through the basement.
  15. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
  16. cptoneleg
    cptoneleg
    Minister of Fire 2.
    NULL
    Jul 17, 2010
    1,512
    260
    Loc:
    Virginia
    Windy or Calm I never notice any difference in the Draft.
  17. wkpoor
    wkpoor
    Minister of Fire 2.
    NULL
    Oct 30, 2008
    1,854
    82
    Loc:
    Amanda, OH
    Beyond the the obvious chimney height many things affect draft. Structures near by, trees, hills, out in a field or in a subdivision. I sit on a knoll with a field behind me in the direction the wind comes from and the chimney is 35' tall and well clear of the house peak on the windward side. Days like yesterday 1 damper wasn't enough.
  18. fishingpol
    fishingpol
    Minister of Fire 2.
    NULL
    Jul 13, 2010
    2,052
    1,130
    Loc:
    Merrimack Valley, MA
