6039 Draft fan settings
rosco6039
5
Bad Axe, Michigan
On the 6039 when you get into the settings what exactly do the draft blower numbers mean? Factory setting is 270, any suggestions? Just wondering? Thanx again for any help.
seems you have a "4 digit ' board (4 arrows up and down) the 270 represents the blower speed. 500 is Max and well 0 is the lowest. so 270 would be 56% of the max capacity. Careful when you adjust you really need to adjust based on the flame quaility in the burnpot.
Additionally, on pellets, you really need to run the default settings for optimum output. Screwing with one parameter impacts everything else, sometimes adversely.
Reactions: Owen1508
Normally true. In some installs and homes some tweeking (fine tuning) can dial in a more effective burn, but I would run it "out the box" for a while until you get use to the way the unit operates. When you are ready to fine tune the unit PM me and I'll give you my extenstion and I can at length explain to you all the factors involved in that process. As SCF stated adjusting without knowledge can adversely effect the stove. It will burn just fine as is, if properly installed.
