    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I recently moved in to a townhouse with a tiny gas fireplace. It only had 2 logs and a very artificial looking straight row of flames in between the two logs. To make it more realistic, I bought 2 small logs to set on top to help divert the flames somewhat. Now I want to use the lava rock & glowing embers. Can I just set them on the base of the fireplace? I heard a man in the store suggest to someone that they place them on a cookie sheet at the bottom of the fireplace, but I can't stick anything underneath the log rack, as it's bolted to the base, leaving no room. If I can't set them directly on the base, could I use something like foil? Thanks, Sammi Smith
    Answer:
    Most of these manufactured fireplaces are preset at the factory, and it is not recommended that you add ANYTHING to the fire. You might be causing a dangerous situation. My advice is to leave the existing logs exactly as they were when you found them.
    #1
    Helpful Sponsor Ads!
Thread Status:
