I heat with an outdoor wood boiler. I currently use a air to water heat exchanger in my first floor unit, plan to run lines to the heat pump in attic, approx 35 ft rise. Do I need check valves on both lines or just the incoming line. Thinking of adding a pump where I will tee off my incoming lines from the heater to push it up the rise to the attic.
Will the head pressure be enough to push the water out of my OWB?
Any Thoughts?
Any Thoughts?
