    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. gyrfalcon Minister of Fire
    Champlain Valley, Vermont
    I'm upgrading from a tiny Tribute to a nice medium-sized Homestead and thinking about wood supply for next winter.
    What's the split length that works best for this stove? Hearthstone says it takes up to 21-inch splits, but then they say the Tribute takes 16-inchers, which it sort of does, but only one or two small ones before you run out of room to get them in through the front door. So 14 I've found is what I need to have to get in a full load.
    So I'm curious about what the longest thing you can get into the stove, and then what's the length that works best for you over the course of the winter?
    #1
    Helpful Sponsor Ads!
  2. Marbles New Member
    Ohio
    The inside door frame is 18" wide and depth of firebox is 12" on my homestead.
  3. gyrfalcon Minister of Fire
    Thanks. I won't have the stove until mid-summer, and I forgot to take those measurements before I left the store, which is around 50 miles from here.
    What length do you cut your firewood (or have it cut)? I can get 16-inch the cheapest, but it seems like a waste of stove capacity. Does 18-19 work the best? Can you get a couple of 20-inchers in?
  4. Marbles New Member
    Ohio
    Yeah you can fit the 20's in with a little work, I have found that 16" load easier without wiggling and burning my hands or gloves, and have tried the 12" a loading N/S to work also equally as well. Problely similar to the Tribute with get the big ones in first on the bottom and then place the smaller in on top. And burn time/heat time doesn't seem to change much between the e/w and n/s loads.
