    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. easternbob Member
    Central NY
    Any one else have this issue? The circ. pump on the back of my EKO 25 seems to have a small air bubble stuck there. I notice a sound when the pump starts back up. Now I guessing it's an air bubble don't know for sure. It's still pumping water so it's not completely airlocked or anything like that. I just seem to hear more of a water rushing sound when it first starts than in the past. I had to clean lime scale out of my side arm and I think it started after that (a lot of new water put into the system). I have a small boiler air bleeder on top of the boiler and I've tried that and I have a air scoop on the primary/secondary loop in the house.
    Or am I hearing something elsee??
    Bob
    #1
    Helpful Sponsor Ads!
  2. Bob Rohr Minister of Fire
    SW Missouri
  3. Bob Rohr Minister of Fire
    SW Missouri
    What pressure are you running? Sometimes bumping the pressure up a few- 5 psi will help remove stubborn bubbles. Is the expansion tank connected to the inlet side piping of the pump?
    Another trick is to add a squirt of dish soap to the system.
  4. easternbob Member
    Central NY
    Bob,
    I'll have to look to see what pressure I have it set at.
    What is the soap supposed to do? Does it help to break surface tension? Are we talking a tablespoon (I don't have storage so my total volume isn't that big)?
    Thanks.
  5. easternbob Member
    Central NY
    Funny thing is I never got around to adding the soap and the bubble(s) must have worked them selves out of the system on their own.
    Does this mean it pays to procrastinate?
