Air compressor help
mithesaint Posted By mithesaint, Jun 3, 2012 at 10:56 AM
  1. mithesaint
    mithesaint
    Minister of Fire 2.
    NULL
    Nov 1, 2011
    512
    81
    Loc:
    NW Ohio
    Not sure if this is the right forum or not, but I'll start here.
    I have a Husky Pro air compressor. It's about 4 years old, 30 gallon upright with a 2 HP motor. It worked fine until recently.
    Now, it doesn't want to run right. It starts up really slow, almost as if it's cold outside and needs to warm up. However, even after a few seconds, it still runs slow. After 10-20 seconds of running really slow, then it speeds up to normal, maybe even a little faster than normal, then it slows waaaaaaay down again, and then speeds up again, and then slows down again, etc.
    Something starts to smell pretty warm within a minute or so, so I have to shut it down. The belt seems fine. The motor spins freely when there is no belt attached, and seems to run normally without the belt. I can manually turn the pulley on the compressor relatively easily. I hooked it up to my 5500 watt generator, and it does the same thing. There is plenty of oil in the compressor.
    Where do I go from here?
  2. heat seeker
    heat seeker
    Minister of Fire 2.
    NULL
    Feb 25, 2011
    2,761
    419
    Loc:
    Northern CT
    Does the motor have a starting capacitor? It may be bad if it does.
  3. DexterDay
    DexterDay
    Guest 2.
    NULL
    I had the same compressor. It came with a decent air tool kit.. Mine did the same thing (stalling, slow or no start) Was a lot worse when it was cold.
    After about 1.5 yrs of use, the Motor seized up.
    I bought a new 30 gallon 200 psi DeWalt compressor.
    Hope you get it fixed... To late for mine.
  4. fox9988
    fox9988
    Minister of Fire 2.
    NULL
    Jan 15, 2012
    616
    198
    Loc:
    NW Arkansas
    Sounds like the belt is slipping. Can you describe the smell-rubber burning, electrical?
  5. greg13
    greg13
    Minister of Fire 2.
    NULL
    Jan 5, 2012
    639
    144
    Loc:
    CNY
    Does it start hard under a load? How about with an empty (0 psi) tank? If it is an under load condition (restart after a pressure drop) I would look at an unloader valve problem. If it is from 0 psi look for a motor or compressor problem. There is oil in the compressor isn't there?
  6. WES999
    WES999
    Minister of Fire 2.
    NULL
    Jan 12, 2008
    1,001
    272
    Loc:
    Mass north of Boston
    You might try changing the oil in the compressor. My compressor was continually tripping the overload/breaker.
    I changed the oil, I used synthetic compressor oil from Lowes. Now it works fine, never trips out.
    Hard to believe that oil would make such a difference but it did. Simple to try.
  7. DexterDay
    DexterDay
    Guest 2.
    NULL
    The Husky doesn't take oil... Its a non serviceable motor. At least mine was a sealed system.
  8. mithesaint
    mithesaint
    Minister of Fire 2.
    NULL
    Nov 1, 2011
    512
    81
    Loc:
    NW Ohio
    We have different setup Dexter. I can add/change oil in mine.
    Anyway, it was a loose belt. Tightened it up and it worked fine. Never thought it would be the belt since it was only 4 years old with pretty light usage. Thanks for all the help.
  9. davmor
    davmor
    Member 2.
    NULL
    Oct 24, 2010
    200
    7
    Loc:
    Northern Michigan
    I just had the same compressor go up in smoke. Motor seized up. Sounds like a common problem. I would be very careful with that compressor.
  10. MasterMech
    MasterMech
    Guest 2.
    NULL
    Replace or re-power by the sounds of it. Dunno if this motor will work but I'm guessing you can find something to work.
    http://www.tractorsupply.com/marathon-electric-reg-2hp-air-compressor-motor-3-450-rpm-3241176
    FWIW: I have a Craftsman Pro 25 Gallon Dual-Stage compressor that has served me well and hasn't showed any signs of slowing down. Requires no maint other than draining condensate from the tank occasionally. When/if I blow it up (and it does work in my shop...) I will replace it with something much bigger but for a homeowner/handyman this thing would be awesome. One of very few Craftsman products I can recommend in clear conscience.
    Alas - I see they no longer make my model 919.167780 :(
