If cold air is being brought in thru the exchanger, is there a different motor for it? I don’t even see it on englands parts page? Cant exactly crack the stove open to see, as its running full blast.
Your combustion blower moves air from the oak through the burn pot up through the heat exchanger in behind the impingement plate then down into combustion blower chamber through the fan and out you vent pipe. The convection blower takes room air and moves it through a chamber on the back side of the heat exchanger and out the vents at the front of the stove into the room. No other motors except the augers.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
