Air Sealing around cathedral ceiling box
NBABUCKS1 Posted By NBABUCKS1, May 20, 2013 at 6:17 PM
  1. NBABUCKS1
    NBABUCKS1
    Member 2.
    NULL
    May 9, 2013
    31
    3
    Loc:
    Kodiak, AK
    I am doing a chimney install and need to air seal around my cathedral ceiling box. Can I use this product? http://www.touch-n-seal.com/gunfoamII.htm
    I plan on running double wall pipe (DVL to Double wall chimney) for the span and the my cathedral ceiling is 15 feet above my stove.
    The stove will run into the cathedral ceiling box. I want to air seal around the box. What type of external temperatures will the box have?
    My main concern is the polyischonerate that is near the box. I am insulating below my rafters with a layer of polyiso. Polyiso is very flamable.
    Is there some kind of insulation/firebreak that I can put around the box above the drywall and below the roof deck?
  2. webby3650
    webby3650
    Master of Fire 2.
    NULL
    Sep 2, 2008
    7,202
    1,733
    Loc:
    Indiana
    You can put any kind of material around the outside of the box. The box maintains the proper clearance to combustibles, no matter what they are made of. At the roof, it will be more difficult. Can you build a sheet metal chase from the box to the bottom of the roof deck?
    Keep in mind that the box itself isn't air tight. You will want to seal all the corners and seams on the box from the inside.
  3. jdp1152
    jdp1152
    Minister of Fire 2.
    NULL
    Oct 4, 2012
    784
    266
    Loc:
    Massachusetts
    fire rated caulk, rockwool insulation in the immediate area.
  4. webby3650
    webby3650
    Master of Fire 2.
    NULL
    Sep 2, 2008
    7,202
    1,733
    Loc:
    Indiana
    100 degrees or less. So, there is no need to do anything special.
  5. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,376
    2,104
    Loc:
    Cascade Foothills, WA
    I sealed with regular caulk around mine. That's the point of the box, to maintain clearance to the pipe.
  6. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,931
    8,638
    Loc:
    South Puget Sound, WA
