Ancient Breckwell/Whitfield Cadet p32i needs combustion motor and pressure switch
greatnw
1
Bothell, WA
Hi All,
First post. Looking for some help on parts sourcing.
My faithful friend is in need of more than just maintenance.
Breckwell/Whitfield Cadet p32i pellet stove insert.
The combustion blower stopped working and I need a pressure switch, too.
I see breckwell has a replacement part for a couple hundred dollars and Fasco has the A082 listed as the replacement for about half that. The fasco spins at 2500 rpm vs the original 3000rpm. Any downfalls to using the 2500 rpm motor.
I haven't been able to source the vacuum pressure switch. Any recommendations?
Thanks!
You need almost same speed motor,recc. do not try.Most whitfields had a pressure switch,even though manual called it a vacuum switch,do not know about your stove,reccomend call a1 stoves or mountain view,parts are available.
