Another Accentra Problem
snoop832
49
Northern NJ
Hello All... First post here.. Love the info I get from this site...
Problem:
No flame adjustments on room temp or stove temp. No matter where I place the temp knob it is consistent with 1 flame height and will eventually go into error 6 blink. Any idea's?
Thanks Andy
I checked the Draft with the meter and it was reading .80 high and about .77 in low (test mode)...
I really think it's the board... Any place online for Harman Parts?? Thanks
How old is the stove? Is there something restricting the pellets from falling into the auger. When unit starts does it push up enough pellets to start stove on first ignition cycle?
I figured out the problem last night.... All is well :eek:) Thanks for the response Rickwa I really appreciate it. Andy
what was thew problem?
I think this is one of those scenarios where merely posting on hearth.com solves the problem. Or it s was you rickwa, you must have magical abilities.....use them only for good.
From my Harmon Advance manual:
A 6 blink status may be caused by several things:
1. Blocked or partially blocked flue.
2. Blocked or partially blocked inlet air.
a. Backdraft damper on the inlet pipe may be stuck closed.
b. If outside air is installed, the inlet cover may be blocked.
3. The air chamber under the burnpot may be filled with fines and small bits of ash.
4. The holes in the burnpot may be getting filled with ash or carbon buildup.
5. Combustion blower fan blades may need cleaned.
6. Fuel restrictions as noted above.
Congratulations on your successful troubleshooting! We are interested as to what the problem was and how it was fixed. It may help those of us with Harman stoves. :)
