Another question from the "who, me?" department
Louise
23
Southeast/south-mid MI
"Who, me?" as in "who, me do my own maintenance/repair work on this thing?" ;)
I'd like to follow the suggestions that I vacuum/clean out the back chambers of my VC Encore Everburn, because I know they're full of ash and creosote particles. My new question is: do I have to take off the top of the stove to do it? Or can I reach it just by taking the stove pipe off the top and going in that way? And if I take the stove pipe out/off (okay, this is going to sound really dumb, please laugh first and then reply), do I have to prop up the remaining pipe sections so the whole thing doesn't fall down? I know, I know, but the only dumb question is the one you don't ask, right?
Also, do I need to buy a gasket kit made specifically for the VC Encore, or can I just go buy the gasket braid stuff and cement at some place like Lowe's?
If I manage not to burn my house down, my insurer will have you all to thank. ;)
Do you have the Encore 2550?
If so, take a look at the schematic in the back of your manual...
There are two wedges - item #21 on either side of your fireback...
Tap them upwards & they'll come out of their slots, freeing up the fireback...
You should be able to remove the fireback - item#28, & get access to the chamber behind it...
It's been a while since I rebuilt one of these, & you may hafta remove the throat hood
- item#27 - as well...
Vacuum the crap out & reverse the steps to re-assemble...
If your Everburn is a ceramic fibre box like in my Resolute, be careful with the vacuum.
When I got my used stove home I put the vac. to it and proceeded to suck a hole in the top of the burn box.
Those are @ $225 to replace.
