    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Mrs. Krabappel Minister of Fire
    Blue Ridge Mountains NC
    I paid just over 600 for my 30, but even at retail price it's a screaming deal. I bumped up from the smaller size Englander (13) for longer burn time and because the 13 really struggled in my drafty house when the temps dropped below 25.
    #26
    Helpful Sponsor Ads!
  2. BrowningBAR Minister of Fire
    Doylestown, PA
    The info on how the current stove works for you allows us to understand if the current stove is meeting your needs and what you will expect from a new stove.
    I find it disturbing that an 8 cu ft firebox is only able to heat for six or seven hours. But, I am also having a hard time understanding if you need all of that stove for heat. At 8 cu ft, and it looks like a very large steel stove, that stove should be blasting you out of you 1,300 sq ft home. When run hot, that stove should easily get the main room to 90+ degrees on a full load.
    If it does not offer that much heat, that either means there is something very wrong with the stove, or your house is far more drafty than we all understand.
    If your house is incredibly drafty and it takes a stove that large to heat 1,300 sq ft, than you WILL have a hard time heating your house with a 3 cu ft stove.
  3. Pallet Pete Minister of Fire
    Ovid MI
    That is an excellent point BB we have a very old home and until last winter it was uninsulated which meant horribly drafty. Before insulating we would load a 3 cubic foot EPA stove every couple of hours and run full blast ! The furnace would still run a couple of times an hour as well just to keep it around 65F 70F range. Now that we are insulated 3 cubic foot is almost too much for us. We get to 90F in a hour if we are not careful. My point being instead of spending on a stove it might be worth saving and spending on insulation. Both BackwoodsSavage and I used the same company I am not sure what Dennis spent but they did our entire house for $3100 dollars. It may sound like a fortune however our heat bills are almost non existant now and we will have made that back by the middle of this winter easily. The link will show you how they did it and what it looks like when finished. Just some thoughts for you to ponder.
    http://www.hearth.com/talk/threads/so-begins-the-insulation-pics.83224/
    Pete
  4. StihlHead Minister of Fire
    PNW Cascades
    Get the 30-NC from HD (they call it an Englander 2,200 on their web site). Even 'off sale' they are $899 locally or delivered to your door (free shipping). If you can wait until Spring, there are usually some HDs online that have them for $649 (with free shipping). They are HUD apporoved for mobile/manufactured homes and they are set up to run with an OAK. They are also EPA and WA state approved (WA state is tougher than EPA, and likely will be the next level EPA-III standard). HD has the best deal on new Englander 30 stoves out there.:cool:
  5. StihlHead Minister of Fire
    PNW Cascades
    30 is just the model number. They also have a smaller model number 13. NC stands for non-cat. If you buy them from HD they have the NCH which comes set up with the pedistal and it also has an optional leg kit, and it has the smaller blower fan (about $100 worth of free options). The OAK is $72 and change from England's Stove Works, or you can make one for about $30 in parts.
  6. David Tackett Member
    Waynesburg, Kentucky
    Where I live HD carries these for 899. I do get 10% discount for being a veteran.
  7. HDRock Minister of Fire
    Grand Blanc, Mi
    Okay, I understand why you need the info, and I appreciate the help immensely.
    To tell you the truth I'm not sure I remember how long a full load will burn, so far this year I've only burned small fires, last year I didn't burn at all, the year before that, I only had a couple of fires, and the year before that, I didn't burn at all, now I am retired and I have more time, and I need the exercise. Last year, I kept The Furnace heat low and put on a bunch of clothes, and that's a bunch of bull crap. Now I would like to, NOT use my gas furnace at all.
    As far as the stove heating the house adequately, there's no problem with that, that big sucker will cook me out if I'm not careful, how much, and what size wood I put in it.
    The stove was here when I bought the house, and yes, it may be bigger than necessary, especially when I shut the doors to two-bedrooms that are no longer used.
    The house is drafty but it is insulated.
    The chimney pulls a good draft, I have no problem starting up a fire even at 50°.
    When I found out on here that the efficiency of the new stoves was 80% compared to 30% for smoke Dragon. I got excited, because that translates into a lot less wood and less screwing around with the stove.
    So there is definitely a new stove in my future.
    I want to be sure and not, end up with an under sized stove, for sure
    Pallet Pete likes this.
  8. HDRock Minister of Fire
    Grand Blanc, Mi
    Sorry , This part I don't know what your talking about
  9. bluedogz Minister of Fire
    NE Maryland
    OAK=Outside Air Kit, used for getting a stove to pull air from outside the house instead of the room the stove is in. Required in some installs (like in mobile homes, I think.)
  10. StihlHead Minister of Fire
    PNW Cascades
    Yes, all HUD certified houses (mobile/modular/manufactured) have to have an OAK installed on any wood burning stove, and the stove has to be on a pedistal. HUD: US Department of Housing and Urban Development (oversees mobile home laws in the US). OAKs are also required on all wood burning appliances during new construction in many areas of WA state, like Kings Co.
  11. El Finko New Member
    Mason Dixon Line
    Dude.
    30.
    StihlHead likes this.
  12. HDRock Minister of Fire
    Grand Blanc, Mi
    Looks like the Englander 30 is kind of popular :)
  13. bluedogz Minister of Fire
    NE Maryland
    Um, yeah.
  14. boatboy63 Member
    Northeastern TN
    I had a similar situation to yours a couple years ago. We inherited a house that was mostly built in the 1890's. The lower level of the house is roughly 2000 sq ft and the only rooms that really had insulation were the ones that had been built onto. We built an upstairs on it that is roughly 1000 more sq ft. It has 2x6 walls and R-19 insulation. When we first got the house 12 yrs ago, we had an old Buck Stove insert that was in the living room. This was truly a smoke dragon and would only offer to knock the chill off 1/2 the lower level on cold day. We honestly would see the curtains move on windy days because house was so drafty. We spent the next summer pulling down vinyl siding, 1 wall at a time, adding a 2x2's and insulating the old and new wall cavities with fiberglass batt. We also installed thermalpane windows. This did help alot, but still is hard to heat. I wish I could go back and do like Pallet Pete did and install the spray foam. It would have been much better and faster in the long run.
    About 2 yrs ago when the 30% rebate was in place for EPA rated stoves, we bought a Magnolia stove from Tractor Supply. The compressor had went out on my 5 ton HP and I did not have the money to replace it so we had to run the electric strips in the furnace at night and very cold days. I got the new stove because our electric bill was hitting close to $400 a month with the heat pump/electric strips and burning the Buck Stove 12 hours a day. We burn half the wood now and get twice the heat. I literally disconnected the heat pump/furnace 2 yrs ago due to bad ductwork under the house. The old duct had holes in it from rust and some had pulled apart so we were trying to heat the crawlspace. We heated with only the Magnolia and had box fans set up all thru the house to help distribute the heat. This old house was like a wind tunnel with all the fans to help distribute the heat and the back rooms were still cool. The living room would often be 85+ just to have enough heat to supply the rest of the house.
    Last year, I decided I wanted to run new ductwork thru the house, but I wanted this on the ceilings of the lower level or built into the floor of the upper level. This was because when the ductwork was under the house, you would freeze when the fan would first come on. Being the cheapskate I am, I used 28 gauge metal galvalume roofing that had not been bent. I ordered it as flat stock and built my own metal brake to bend it. I had to custom make the duct due to the sizes I needed to route it thru the house. I extended my return for the furnace to within 10' of my Magnolia and with it being on the ceiling, it would pick up the heat. I just got it completed last week and have now done away with all the box fans in the house. Since the compressor is still bad, I wired my furnace/thermostat up so that the electric strips will work in stages when called for. The thermostat is on the living room wall about 16' from Magnolia. I have it set up so that when the temp hits 79 at the stat, it calls for cooling, which is only the furnace blower/fan. If the temp drops below 73, it will call for the first stage of electric strips. At 72, it will call for the second stage of strips. This should all work great on the very cold nights or when the stove goes out. It also keeps the living room from being 85+ just to heat the house. It is still a little cooler in the back rooms, but nothing like it was. This was all a long drawn out process, but I think it will be much better in the long run. I started building my own custom made outdoor wood gasification boiler a couple years ago, but still haven't finished it. Either way, the ductwork had to be completed first.
    My advice to you would first be to get a modern wood stove (new or used) to help get thru the winter. You will burn alot less wood and get more heat. Next year, if you plan to live in the house for a long term, bite the bullet and insulate with the spray foam as mentioned above. It may have a high inital cost, but once done, you don't have to worry with it anymore.
  15. HDRock Minister of Fire
    Grand Blanc, Mi
    Well I have some fans set up now, blowing the cold air toward the stove room ,at 30 deg outside , the temp difference to the far end of the house is 4 deg :cool:
  16. EatenByLimestone Minister of Fire
    The cult following seems to change as time goes on. The 30 has a following, the BKs have a following, and for a while the PE Summit's had quite a following. I don't know if it is a cult as much as it is a bunch of people who took advantage of a good price.
    The stoves at Lowes also work well. I picked up a Century that I now use in the family cabin for $242 out the door a few years ago. The Pleasent Hearth stoves they have now look to be of good quality. I'd buy one and I saw they were on clearance last time I was in there.
    Matt
  17. CR250Rider New Member
    Seattle
    Thanks so much for all the great input.
    You guys make a nubee feel welcome!
