Hey I just recently purchased my house and am looking to install a new wood stove in my den. The house is a 2,400 sq ft 2 story colonial and the den is just off the side of the main section of house. The room is roughly 18x15 and in the corner that i wished to install the stove it has the kitchen on the other side of one wall with 59 inches from the corner of the room to the doorway into the kitchen, the other wall is actually a sliding glass door to go outside. The non moving section of the door is in the corner and when the door is fully open it is 39 inches from the corner of the room to the opening of the doorway. I was hoping to install a stove caddy cornered so that the glass is visible both how I have the room set up now and in the future when I renovate the room some and the furniture is moved to the other wall. ( I'll attach pictures and a floorplan withing a few days).
I was hoping to install an Alderlea T6 since I have heard nothing but good things about it, and it could heat my whole house yet be turned down to not overwhelm the room and it has the heating trays on the top. The problems I am running into is the area taken for the hearth pad, on chinmeysweeponline it says that the length of the sides of the pad must be 56" (https://chimneysweeponline.com/cpacaldert6.htm). This would put it well into the doorway to go out onto my deck. So now I am wondering what stove and pad would I be able to fit into this 59 inch by 39 inch corner.
Additionally I was thinking that the only way I could run the chimney would be to have it go up a few feet, a 90 degree turn out the wall over the non moving part of the sliding glass door, then another 90 and run it up the side of the house. How would this work for the draft by not having it straight up and having it outside. I cannot really runs a pipe straight up as the entire second floor is finished and it is actually a bathroom over the den so it wouldn't be be easy to without a lot of work.
Unless anyone has any suggestions idk what I could change other than to reframe the sliding glass door and more it over about 2 feet so that there aren't clearance issues and sheet rock the old area it used to be, but that's more work than I wanted to do. Any input or ideas would be greatly appreciated. As I said Ill try to add pictures in a couple days in case anything I said was confusing.
