    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Bagged Wood New Member
    western Va.
    I have a Whitfield Advantage Plus. After 24 hours or so burn time my glass is dirty. It is not black soot it just seems like ash is sticking to it. When I clean it I can just vacuum it and most everything cleans off like that but still has a slight film on the glass that I clean off with stove top cleaner. I have replaced toe door gasket and that seemed to help some but I still get the ash hanging on the glass. I have adjusted the draft too all the way from soot on the glass to what I guess must be too much air cause I have to scrub the glass to get it clean. Any ideas on what I should try?It runs on low most of the time.
    I have cleaned the air wash gap at the top of the glass too.
    #1
    Helpful Sponsor Ads!
  2. hearthtools Super Moderator
    If it is not ash or a light gray build up
    but it is sticky
    Sounds like you need to give it more air and or do a full service on the stove and venting
    Or you dont have it vented correctly from the start.
    The the Yellow sticky post at the top of the pellet/corn room
    this is the best link to start at
    http://www.hearth.com/econtent/index.php/forums/viewthread/13419/
  3. Bagged Wood New Member
    western Va.
    It is not sticky at all. It is vary dry and can be wiped off easy. It is kinda grey looking.
  4. hearthtools Super Moderator
    then your stove is working fine
    you may have to Clean out the Air wash gap on the glass to be sure air is flowing through to keep the glass kind of clean
    it is normal to get a Light gray or Brown haze on the glass
    Bay window stoves are harder to keep clean because it is hard to keep the heat and air on the glass.
  5. Bagged Wood New Member
    western Va.
    Thanks ......guess I will just keep cleaning it every day cause thats what I have. Sure do like seeing the fire through a clean glass though. :lol:
  6. Xena Minister of Fire
    South Shore MA
    Running it on low most of the time is probably the culprit.
    I get the same if I run it on low for a day. Kick it up a couple
    of notches and your glass should stay clearer longer.
Thread Status:
