Now that I am into cold weather and burning all day I have some higher temperatures on the wall behind my stove. The wall behind my stove has 1/2" of wonder board 1/4" mortar and 1/4 of tile on it. Since the wall is attached directly to the studs it is considered combustible Using my IR gun I am getting readings as high as 125 - 130 degrees Fahrenheit . Is this too hot? the other side of the wall is a closet and that side of wall is 90 degrees. I have the required clearances on everything I just want to make sure this is safe or should I go ahead and buy a heat shield or double wall pipe?
The stove is a woodstock fire view.
