With a wood insert should you insulate or block off the ash clean out in the bottom of the fireplace where in my case, the insert sits on top off? It can't help to have cold air coming up from the basement and cooling down the insert/
Jim
Jim
It probably wont matter much if you have a block off plate and the insert is sealed around the front trim. If not, I would just give it a shot of high temp silicone and seal it. You can always open it back up.
I used that for the air intake for the wood stove - dropped the air intake down their, sealed it up, and I pull combustion air from the basement. Works pretty well to keep the basement from getting stale from lack of air circulation, and keeps the drafts down in the house. That's another option.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
