I have 1/2 acre lot in a suburban area so I don't have woods to discard ash easily.
What is the real story on ash as an supplement to lawn/soil.
Exactly. Test your soil pH and nutrient levels before going at it with wood ash. It may be beneficial if your soil is super acidic to help neutralize it. In addition, each plant/fruit/vegetable/whathaveyou thrives in a different type of soil. Test your soil, figure out what you are trying to grow, and then use your wood ash to adjust accordingly. If you just start spreading large amounts of it you can literally scorch the earth you are spreading it on.Ashes are good for soils with low pH or acidic soils, if you had a lawn installed with a particular grass seed, look up that variety and see if it needs acidic soil or alkaline soil, any grass or plant / bush that likes acidic soils avoid the ash.
When do you recommend spreading on lawns?We buy ash to spread on hayfields by the semi-load. A soil test would tell you if your soils are acidic (odds are pretty good here in the northeast with our glacial soils and high rainfall that they are acidic). You can check with UMass Extension for a test kit. When applying on fields the recommendations are to stay below 5 T per acre in a single application to avoid smothering the growing grass; other than that, we go by the test results. The 5T/ac works out to about 5 sq ft per pound of ash.
If you are burning black walnut, oak and locust that you cut down in the forest, you are burning "organic" wood. It is hard for me to see how you could get lead or mercury, or arsenic in that wood, however, it ought to contain beneficial minerals.
