I read some of you use a barrel to dump your ashes in. I put one out the back door. Problem is when I dump the bucket in there it plumes all over blowing into the house. Any tricks here? I guess I'll have to move it farther away.
AMEN Pen....that is perhaps the most important thing. A lid....pen said:+1 to scotty's suggestions, plus make sure that barrel has a lid.
pen
Scotty Overkill said:you definately want it away from your house as well as any flammables. Fly ash (aka the dusty stuff) is so light that as soon as you disturb the surrondings it is up and all over the place. So you will have a hard time not making a mess, you could consider laying the bucket or ash pan over slowly right above the ash that is in the barrel and sliding it out slowly (instead of "dumping" it) as to not disturb the fly ash too much. But you definately need to keep your ash barrel away from your house.
firebug said:I read some of you use a barrel to dump your ashes in. I put one out the back door. Problem is when I dump the bucket in there it plumes all over blowing into the house. Any tricks here?
Ken45 said:firebug said:I read some of you use a barrel to dump your ashes in. I put one out the back door. Problem is when I dump the bucket in there it plumes all over blowing into the house. Any tricks here?
Close the door?
oBeGreen said:I use a 10 gallon, galvanized can with a snug lid. It looks like a small garbage can and works very well. They are about $10 a the local hardware store.
Marty S said:6. Doubled plastic bags for cold ash disposal
Marty S said:Also NG is putting glowing coals in a galvanized metal can, even with a lid.
Hot coals with galvanized metal = zinc vapor = especially NG.
- This may appeal, however, to those who like to breath a little poison; i.e., the smell of wood smoke. - my sarcasm - do not do it. Zinc vapor is very toxic.
I use a galvanized bucket too. and I, too, have welded lots of galvanized over the years. Now I don't want to breath it in a confined space or for long periods of time, but I think incidental contact with it is not going to kill you. I work in a locomotive overhaul shop and I can tell you I breath a lot worse stuff than that galvanized.........Battenkiller said:Marty S said:Also NG is putting glowing coals in a galvanized metal can, even with a lid.
I've welded plenty of galvy because it's so easy to scrounge. I've never gotten sick because I hold my breath and keep the breeze to my back. I used to be plenty worried about, though, so I looked up the toxicology of zinc fumes and was surprised to find it's not harmful to you... even if it does make you feel pretty sick for awhile.
Even so, I think BG's fine with his galvy ash bucket. That is, unless he get the thing glowing orange. Boiling point of zinc is 907°C.
Ken45 said:Cringe.....Marty S said:6. Doubled plastic bags for cold ash disposal
Yes, that's fine for truly COLD ash disposal, but I would wait at least a week....and then still be worried. Coals insulated in a thick layer of ash can stay warm for a LONG time.
Sure, it's probably safe after several days....probably.....
I just wouldn't chance it, stick with a metal container and dump them on the garden or something. DO NOT put out possibly warm ashes for the garbage man. Garbage trucks on fire are no fun. Ken
Marty S said:Battenkiller said:Marty, I agree that a dose of zinc as described in that article would be very bad, but so would a dose of wood smoke. It sounds like he actually died from more than just the zinc. I am sure that pipe, when put in the forge, reached high enough temps to outgas manganese, vanadium, lead and whatever other trace metals were in that pipe. So yes, that would be very deadly. But all I was saying is that incidental contact with it won't kill you, and that bucket (even when filled with hot material) would have a hard time ever reaching the burning stage where you would have the galvanized coating burning. We have a raging fire inside the stove going and the metal stove never goes.into the 900 degree range, and that is where you need to be for the zinc to burn off. But if you have an alternative to use, there is nothing wrong with that.Marty S said:Here's a good case to take in about Zinc Metal Fume Fever - Just ask Jim -"paw-Paw" Wilson.
http://www.anvilfire.com/iForge/tutor.php?lesson=safety3/demo
But then, there are those who believe breathing just a little bit of poison is just fine...
Aye,
Marty
Scotty Overkill said:Marty S said:Battenkiller said:Marty, I agree that a dose of zinc as described in that article would be very bad, but so would a dose of wood smoke. It sounds like he actually died from more than just the zinc. I am sure that pipe, when put in the forge, reached high enough temps to outgas manganese, vanadium, lead and whatever other trace metals were in that pipe. So yes, that would be very deadly. But all I was saying is that incidental contact with it won't kill you, and that bucket (even when filled with hot material) would have a hard time ever reaching the burning stage where you would have the galvanized coating burning. We have a raging fire inside the stove going and the metal stove never goes.into the 900 degree range, and that is where you need to be for the zinc to burn off. But if you have an alternative to use, there is nothing wrong with that.Marty S said:Here's a good case to take in about Zinc Metal Fume Fever - Just ask Jim -"paw-Paw" Wilson.
Aye,
Marty
That's reasonable and a dose related statement. We agree! Thanks.
Don't know about others, but I prefer to avoid breathing even a little bit of poison.
Aye,
Marty
Battenkiller said:Scott, not to nitpick, but the point where zinc burns off and forms zinc oxide is above 900ºC. That is actually above 1600ºF. Like I said, glowing orange in daylight. Not gonna happen in an ash bucket, even hard inside the stove itself throughout much of the burn.
At any rate, I maintain that using a galvanized ash bucket or ash handling tool is perfectly safe.
Marty, Jim had COPD and breathed in large amounts of a mucosal irritant leading to death by pneumonia, not poisoning. Any heavy concentration of particulates might have led to his demise as Scott pointed out. And the info from OSHA is regarding zinc chloride, not zinc oxide. It's often not the metal itself when it comes to toxicity, it's the compounds it forms. For example, elemental mercury in its liquid state is fairly benign when handled due to extremely poor absorption through the skin. However, just a few drops of dimethyl mercury spilled on a latex-gloved hand in the lab killed a prominent researcher on mercury toxicity. She died many months after the exposure, and all of medical science - including intense chelation therapy - could not save her.
firebug said:I read some of you use a barrel to dump your ashes in. I put one out the back door. Problem is when I dump the bucket in there it plumes all over blowing into the house. Any tricks here? I guess I'll have to move it farther away.
