Asking the experts for help
TroyRoy Posted By TroyRoy, Jul 20, 2013 at 11:18 PM
Thread Status:
  1. TroyRoy
    TroyRoy
    New Member 2.
    NULL
    Jul 20, 2013
    1
    0
    Loc:
    Troy,NY
    Hello All: I'm new here and looking for some experienced help. My son has a condo with a ZC prefab metal firebox insert with a round damper. He presently has gas logs that are old, and need replacing since last year when there was a gas smell, that's when we shut the unit down, turned off the gas. Covered the glass doors with plastic to keep the cold draft from the room. He's looking to get this unit running again. the present surround has no vents, top or bottom no blower. the current logs give little or no heat into the room.
    Could someone give me some ideas as to which set of Natural gas logs would give him the best heat into the room for the $$$
    looking for unit with a remote and safety pilot
    Thank You
  2. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,648
    1,200
    Loc:
    Averill Park, NY, on Burden Lake II...
    Gas logs are "Decorative Appliances," i.e. they are not heater rated. In an inefficient ZC box they'll be sending gas dollars up the chimney & that set-up will always be cold. He needs to have a sealed-combustion gas-burner installed. It could be a free-standing stove on the hearth in front of the ZC box or an insert INSIDE the ZC box. He already has the gas line there. Might as well do it right if he wants a heat source...
  3. sticks
    sticks
    Member 2.
    NULL
    Jan 13, 2012
    134
    23
    Loc:
    Central IN
    I keep hearing pilots are not allowed in NY. Is this true?
  4. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,648
    1,200
    Loc:
    New one on me...
  5. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    X2 for a direct vent gas insert for that fireplace. Might have to be a small one (check out Enviro E20) or some modifications done to existing firebox. Either way, then you'll have a real heater, not a decorative appliance (the gas logset). Good luck
Thread Status:
