Auger only spins when hooked to jumper
heatherlb2002
3
Indiana
I have a pelpro pellet stove and the auger will only spin if it is hooked to a jumper. While hooked direct to stove it does not spin. The auger light lights up every few seconds when it should be dropping pellets but auger does nothing. I bypassed the vacuum sensor to try that and still nothing. Any ideas??
Did you try running motor,jumpered,while installed?Auger may be jambed.If ok,check voltage at motor when light flashes.
