auto draft control for woodstove
pyro68
171
east coast
looking for a auto draft control to mount on a wood stove, similar to the ones mounted on the old VC stoves. don't really know what to call it, some of the old Jotul stoves had it on the door, round disc type. Any one have any ideas where one can be purchased?
Thanks
rk
The new Vermont Castings stoves still have a thermostatic damper as do BlazeKing stoves. I don't believe this can be retrofitted.
i installed a simple electronic temp controller on my PE summit.there was a so called ebt on mine.i took it off and replaced it will this.its not variable.just something simple that cant really screw up and get a overfire while your away.i have it set up so i set my main dampner to the heat output and and burn time i want.then as the wood burns down and cools i have a set temp to open up the secondary air valve and add more air.
