Automatic bulk pellet loading for pellet stoves?
Andrew Robinson Posted By Andrew Robinson, May 14, 2014 at 4:41 PM
Thread Status:
  1. Andrew Robinson
    Andrew Robinson
    Member 2.
    NULL
    Feb 4, 2013
    26
    0
    Loc:
    Yellowknife NT Canada
    Hello again,
    Does anyone know of a system for loading wood pellets from a bulk storage into a wood pellet stove hopper?
    This is a new installation - back problems prevent us from filling the stove with 40lb or even 20lb bags.
    Some variation of a vacuum or auger system used for pellet boilers?
    Andrew
  2. chken
    chken
    Minister of Fire 2.
    NULL
    Dec 7, 2013
    1,102
    226
    Loc:
    Maine
    The Biowin has a vacuum system that they use with their Firewin pellet boiler/stove. I'm not sure if it's adaptable to 3rd-party stoves, but it might.
  3. TimfromMA
    TimfromMA
    Minister of Fire 2.
    NULL
    Mar 6, 2014
    2,306
    838
    Loc:
    Central MA
  4. ScotL
    ScotL
    Feeling the Heat 2.
    NULL
    Feb 7, 2011
    376
    136
    Loc:
    Central Maine
    My uncle's Kedel has a bulk hopper outside that is auger fed into the boiler. I've seen a sales flyer for one that works with a sack. It moves around on the bottom to get the whole thing empty. There's quite a few options for bulk pellet transfer.
  5. Andrew Robinson
    Andrew Robinson
    Member 2.
    NULL
    Feb 4, 2013
    26
    0
    Loc:
    Thanks for all the suggestions. Here are a couple other ones I found interesting:
    A wall mounted hopper that can be operated with a shop-vac - intended for corn stoves, but a similar system would probably work for pellets.
    http://www.cornvac.com/index.html
    And - from Sweden - a bulk pellet system that uses your central vacuum as a suction source:
    http://www.pellvac.com/e/start-e.php
    We are probably going to use a system like the Swedish one. Apparently there is even an optional 3-way valve that allows you to use the central vac to clean out the stove!
    A
Thread Status:
