Avalon Arbor leakes
Roger K
8
Capital region New York
I have a arbor that has developed a smoke leak. I can't seem to pin down where it leaks from. I can smell and see a little haze around the stove on start up especially. I have replaced the doors seals. Is there a common problem I should look for? The stove is about 5 years old.
1. Dollar bill test your door and make sure it is adjusted correctly. 2. Turn all lights off and check exhaust area with flash light on stove start up to isolate where the leak is coming from. 3. Do 1 and 2 only if the stove and exhaust venting has been cleaned stem to stern, front to back and inside and out. A blockage can cause smoke to back feed into the house. That's what I would do.
