We recently just had a 1995 Avalon Olympic woodstove professionally installed. Because the insert wouldn't fit as far back into the chimney firebox as needed, we asked that the installer do a slight modification to the surround to make it fit flush with the brick chimney on the insert. Unfortunately, he did a really bad job and we are not sure where to go from here. It is definitely not flush and the whole thing is a bit crooked. We had our first fire the other night and it seems that now the surround is starting to bow. We really don't want him to come back out and screw it up any more then he already has so we may try and fix it ourselves. Our thought is to use a heat resistent adhesive and glue them on to the outer side shell of on the stove and then just have the top surround slip on top of that. Will this even work? Is it a bad idea to try and adhere the surround to the insert without screws? Any other suggestions? I can post pictures if needed
