Baby Bear Firebricks
Starbuck
1
Asheboro, NC
Thanks for a great site and sharing your expertise regarding Fisher stoves. I am a new member of the Fisher family of owners with my baby bear being delivered this morning. Some of the firebricks are broken and the firebricks were delivered in a separate container. I would appreciate someone sharing the brick pattern specific to the baby bear. Thanks, Starbuck
Early, pre 1980 models with flat top door;
https://www.hearth.com/talk/threads/baby-bear-firebricks.87254/
Model VI (UL listed with arch top door with bottom and rear shields);
Using the info Coaly gave you let me add something. If this is the first stove to put brick in be sure it is shop vac clean or all the brick will probably not fit. If you have some brick that are cracked or broken use them on the bottom. Install the back first sides next then the bottom. The bottom held the sides and back in place. good luck.
Reactions: Calvin
