Barometric Draft setting: H or V when on angled flue that is neither H or V?
Monaco
Burning Hunk
Sep 13, 2015
111
Indiana
Do I set the barometric draft to H or V when my flue is somewhere near a 45-degree angle?
I don't think it really makes much difference. I have tried it both ways on a vertical install, worked the same either way
What are you guys talking about? The orientation of the barometric damper? Doesn't it have to be horizontal for the counterbalance on the flapper to work right?
What are you guys talking about? The orientation of the barometric damper? Doesn't it have to be horizontal for the counterbalance on the flapper to work right?View attachment 165752
On other brands (Fields) the little sliding weight can be mounted on the left or right side of its bracket, it is labeled H or V. As I understand it you are supposed to move the weight to the appropriate side depending on if you have the baro mounted in a section of vertical or horizontal pipe. Like I said before, mine was in a vert pipe, seems to work the same with the weight on either side...
Reactions: Monaco
Exactly my scenario. It has two sides, I put mine on H for horizontal, because it's probably closer to that than vertical. I'm very surprised the instructions don't mention this, when they even show an example diagram of it being installed on an angled flue.
I think I get it. I installed my damper in a tee and rotated it until it was horizontal.
