to date, I've worked with PEX a lot for plumbing, but in that setting, 3/4 " diameter is the largest that I have worked with
One of the features that won me over to PEX is the ability to make it "go where you want" without a lot of fittings- such as around corners without elbows, using those curve-holding supports used instead of elbows
I've not yet worked with or even handled PEX in the sizes such as 1.25 or 1.5 inch that I'm considering using to tie my primary loop to my storage tank
I know that even at 3/4, PEX is pretty "assertive" in displaying its desire to return to its original shape, so I have to imagine that at 1.25 to 1.5 inch diameters, it's pretty obstinate stuff to handle in general and hold in any shape.
does anyone know if you can still get PEX in the 1.25 or 1.5 inch diameters to bend, and stay bent?
if so, what radius can you work with, and what do you use to hold it in place?
thanks
thanks
