Best Sealant for Sealing Air Leaks in Stove Pipe???
BurnIt13 Posted By BurnIt13, Feb 10, 2012 at 2:51 PM
  1. BurnIt13
    BurnIt13
    Minister of Fire 2.
    NULL
    Jun 10, 2010
    622
    74
    Loc:
    Central MA
    I've been having some troubles with my fires lately and it dawned on my that the troubles started when I gave my chimney/stove pipe. I used the SootEater to clean out the pipe from the bottom up.
    Anywho...I didn't have any incense sticks but I lit a match and the flame almost got blown out buy the suction through the stove pipe seams. Obviously, I need to seal them up.
    Does anyone make a flexible silicone based sealant that will survive very high temps? I know Rutland has a silicone version that will survive up to 600 degrees but I don't think that will survive near the stove collar. I have double wall chimney/stove pipe and the 600F silicone would probably be fine except for the first few feet off the stove.
    There is also Rutland's Hi-Temp Stove and Gasket Cement. I'm sure it would do a good job sealing but how does it doesn't appear to be flexible once cured. How does it hold up to vibrations and the natural expansion/contraction of the metal pipe? The stove pipe does get banged around a bit when the SootEater is going through there.
    Any suggestions?
  2. pen
    pen
    There are some who call me...mod. 2.
    NULL
    Staff Member
    Aug 2, 2007
    7,777
    1,532
    Loc:
    N.E. Penna
  3. BurnIt13
    BurnIt13
    Minister of Fire 2.
    NULL
    Jun 10, 2010
    622
    74
    Loc:
    Central MA
    Thank you. How "clean" is this stuff? My stove pipe is pretty and I'd hate to make it look like I smeared peanut butter all over it. I initially thought silicone just because of the ease of using a caulking gun.
  4. oldspark
    oldspark
    Guest 2.
    NULL
    You take the pipe apart and put it on the joints as you put back together, if done right you wont see it.
  5. pen
    pen
    NULL
    Staff Member
    Aug 2, 2007
    7,777
    1,532
    Loc:
    N.E. Penna
    The stuff in the picture that I shared w/ you is black in color, so that helps also.
    The stuff I used wasn't black and I had to be much more careful with it.
    pen
  6. pen
    pen
    NULL
    Staff Member
    Aug 2, 2007
    7,777
    1,532
    Loc:
    N.E. Penna
    As an additional note, if the cleaning is what caused your problem, I would think that this issue would have been present when you first started using this system when new and clean.
    Sure you didn't seperate something when doing the cleaning? Or even partially block the cap w/ a chunk of creosote that didn't bust up? Put a baffle back incorrectly?
    I'm asking because usually a problem like this would be an ongoing issue, and not something that suddenly appears.
    pen
  7. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Don't be afraid to smear it on. Put the pipe together and take an old rag and wet it. The excess wipes right off very easily.
