best ways to store tires during off-season
snowleopard
1,515
Hi, all.
I've been poking around the web for this, and am not coming up with answers I need, so trying here.
I have three vehicles that I swap tires out on spring and fall, plus a couple of back-up tires. Taking up a bit of space in the garage, and I'm wondering if I could do as well by keeping them outside. Two of the sets are on rims, so trying to prevent rust, sun damage, etc.
Options:
I have a sloping bank, drainage is good and they'd be shaded by the garage.
I have a little storage shed I could drag up the hill and deputize as the tire-shed.
I could just leave them outside behind the garage and throw a tarp over them, or just leave them out.
I could leave them in the garage (not the end of the world, but space is always nice to have.
Input appreciated.
Thanks, Lee.
I've read about people tarping tires--does this lead to rust on the rims?
I can't really help, and I realize how garage space is always at a premium, but I have the tires for my two cars stacked up in the garage. I imagine, if one really wanted to bad enough, another set of tires could be put on top of that. The footprint on the garage floor would only be that of the largest tire. Of course, it'd have to be up against a wall...
Tarp on the tires keeps the rain off but there will be some condensation which you don't want. Lee has it right; cool dark place and make sure it is a dry place. If not a dark place, then just inside where the sun and rain won't hit the tires.
Got room above the garage rafters?
There are also storage devices that will store items up against the ceiling, too, so they'll be out of the sun, and relatively cool. They take up no floor space.
Like the above answers say, dark and dry where ever you put them. Sunlight and dampness can cause the tires to crack in just a few months, even a new tire. I made the mistake one year of storing my motorcycle in a shed with a dirt floor, and the dampness over winter basically ruined my front tire, only a year old. Have you thought about looking on craigslist for one of the rubbermaid plasit type sheds or storage boxes?
Good suggestion. I tried a version of that, but stacking my smaller tires with rims on top of my larger ones w/o didn't work, and I just put them in three stacks sorted by vehicle. I can't go too high, because I have shelves almost all the way around the garage, except by the door and the (currently dead) boiler. However, I can do a modified version of your suggestion, by stacking the little rims on top of the bigger rims, and the consolidating the rimless tires. That takes me down to two stacks, and that's something I can do right away. Seems obvious in retrospect, but sometimes you just have to talk things over with other people for that to jump out at you.
Thanks for the emphasis, Dennis--I didn't realize the moisture could add to the problem.
My trusses are rocked in and insulated, so no attic access ('cept to those dang squirrels! It's war now . . . ) I've seen some of those dangly things advertised, but hate to put that much weight on the rafters. They'd probably be fine, but I'd rather err on the side of caution.
Glad I posted here, as I am learning good stuff. Those plastic storage sheds don't have a real good rep around here for standing up to the snow loads, but I am leaning towards the shed solution.
flyingcow said:
Use your little storage shed.
So after reading this thread, I walked out to the garage and measured my tire stack, then down to the storage shed and took dimensions. It had been an old playhouse, and even though the kids that lived here before are pushing middle-age, the shed is in surprisingly good shape (raw plywood, built on joists that are laying on some aspen poles, also in surprisingly good shape. The thing was intact enough to rock as a unit when I pushed on it, but too heavy for one person to pick up.
It's 6-1/2'x4x5-1/2h, so would hold all my tires and maybe a bike, too. The flat roof is starting to show its age, but I could put a pole across the top and drap a tarp to keep it from going any further downhill. Good ventilation, and I have a flat a place behind the garage where I could tuck it. I've got a little Toyota pu on the books next for repair work, and once that's up and running, I can drive down to the shed and load it on there with a crew of willing teenagers, can even drive to that spot behind the garage.
A few serendipities: I found a big old washtub down there that filled up w/water, froze, so there's a hole at the seam and it's all curved out on the bottom. Filled with soil and set on a small tire, I've got a great little tomato garden or such. Also found some good firewood down there, including a laying-dead poplar, suspended on the stump, about 6-8" and 30' long, next to the shed. May as well cut that up and throw it in the truck while I'm there.
So I have information and a plan now: consolidate the tires into two piles for now, and move that shed when circumstances permit. I'll probably wait on filling the shed until the next time I swap out tires (three months away), and then use it from there on out. Unless plans change. Like if I get ahold of some glulam to make a workbench in that corner . . .
I appreciate your input in this, folks. It's good to have a plan.
kingston73 said:
Like the above answers say, dark and dry where ever you put them. Sunlight and dampness can cause the tires to crack in just a few months, even a new tire. ...
Good grief?!?! I wonder how they ever survive *ON* the car then??
They don't! I have had to replace tires that were not worn out because they dry rotted due to age and exposure. Granted, it took years, but it happens.
Most people wear out their tires before they age that much.
Moisture inside the tire degrades the liner ahead of its time, too.
Expensive as tires are to replace, I'm going to err on the side of caution and move that playhouse-->storage shed up behind the garage. That way they stay dry, they are out of the sun, and they are easily accessed when there is no snow back there. They also will be surrendering the footprint in the garage that they take up. If I go over to year-round tires, I have a bike shed, and that eyesore down hill from the front window gets moved and transformed into something useful. Win-win.
I wondered about this myself, but decided that plastic garbage bags would deteriorate pretty quickly, hold moisture in so that the rims could rust, and might not even block sunlight all that successfully. I believe that they are designed to break down in sunlight.
Sometimes they don't! My wife and her sister rented a new car in Tampa last April. On their way back to the airport they had a complete blowout of the rear passenger tire. It took out part of the rear bumper when it blew! The Avis guy that came to pick them up said the tire had just rotted. There was a lot of tread left. Fortunately this was on the on-ramp to the causeway. It would have been hell if they had no place to pull over. As it was they missed their flights.
