I have bio 60 and gasket went bad but it was because piece of refactory damage it and I tried to close door hard it was gassing big time had to get door close fast I pushed damper open to take heat away from bottom to look at it any way after replacing gasket it still leaked bad I though door was sprung but it was not it called nh and zennon went through the trouble shooting list but no fix so I run 3 weeks in cold with leaking bad and not much heat output I called him again and this time we figured it out when I cleaned out boiler I didn't clean the side passages in lower chamber count see them and I forgot what it looked like in the beginning so all clean no leak working great again in md we had a cccold winter than in past long time broke some records hope some of my mesakes helps someone else out mark oh I have my 60 in an outbuilding so smoke was not an problem if some one asksIf the refractory is bad it will be covered under warranty.
after the first failure I replaced the bolts with hi- temp stainless steel and put a big glob of refactory cement on parts that stuck out been 6 mo no problem this spring ill chip it off and take a look but it looks ok nowI run it pretty well wide open with fan at 100% but my current 450g storage hasn't been enough to carry us over with the current winter fun we've had this season. Hopefully, 1500g next year and 0 idle times (crossing fingers for new house).
