black class A chimney?
stovepipe? Posted By stovepipe?, Oct 29, 2006 at 5:20 PM
Thread Status:
  1. stovepipe?
    stovepipe?
    New Member 2.
    NULL
    Dec 1, 2005
    71
    0
    is there such a thing? Any reason the SS stuff can't be painted with black stove paint? purely out of aesthetic concerns.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,806
    8,589
    Loc:
    South Puget Sound, WA
    Not stove pipe, but I painted the new stainless flashing on the front of the house. It looked like the house had a set of braces on it before I painted it black. I used a Rustoleum satin black metal paint. So far after 4 months, the paint is holding up well. I would think stove paint would work. Use coarse steel wool on the surface first to add tooth.
  3. cbrodsky
    cbrodsky
    Member 2.
    NULL
    Jan 19, 2006
    517
    0
    Loc:
    Millbrook, NY
    Our class A install was a little unconventional due to access issues in the chase; ended up with a stub coming through the ceiling with the transition to stovepipe. Painted it with flat black stove paint and no problems - looks great!
    -Colin
  4. pjmac
    pjmac
    New Member 2.
    NULL
    Jan 23, 2006
    20
    0
    Loc:
    Coshocton, Ohio
    I painted my SS flue pipe with Rutland black high temperature paint last year and it still looks fine today. My pipe is on a Harman XXV pellet stove so the temperatures are not as high as a regular wood stove.
  5. hearthtools
    hearthtools
    Moderator Emeritus 2.
    NULL
    Jan 6, 2006
    2,026
    32
    Loc:
    Oakhurst, California, USA, Earth
  6. DriftWood
    DriftWood
    Minister of Fire 2.
    NULL
    Apr 5, 2006
    718
    0
    Loc:
    Bluewater Area, Great Lakes
    Black painted stainless steel radiates heat better than the same plain clean stainless steel metal.
    “Physicists calculate how much light a perfectly emitting object would give off at a given temperature, and then they multiply that by a number between 0 and 1. objects that are black at room temperature are close to 1, objects that are shiny or white are close to 0.
    That’s because to conserve energy, the best absorbers (those looking black) have to be the best emitters."{*}
    {*}Anton Smirnov
    See this thread > http://www.hearth.com/econtent/index.php/forums/viewthread/3142/
  7. Metal
    Metal
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    699
    18
    Class "A" can definately be painted or you can usually get a trim sleeve to cover it if you don't want the mess of field painting. You can usually get Class "A" with either a Stainless Steel Casing or Galvanized/Aluminized Casing, so get the latter if you want to paint it as it takes paint better and is cheaper.
Thread Status:
