Blower Fan for Old Schrader
gaitski
2
Moscow, ID
Hey all, I've got an old Schrader double door stove with a hookup in the back for a blower. The hookup just connects to 6 tubes that run over the firebox, so any air that blows through the system is heated and pushed out. I inherited the stove with the house, and the previous owner had a McGuyvered small blower fan in a box hooked up to the back which recently went out.
My question is, does anyone know of a supplier for the fan that was intended to go with these stoves? I'd hate to spend $100 on a new motor if there was a better fix out there. Thanks!
It's somewhat separated from the rest of the stove, so yes I think it would be cooler. The house that it's in is actually a rental that I manage, otherwise I'd take and post some pictures.
well, my thoughts are that, as long as it's separated from major heat exposure, a small form factor cooling fan from an old rack mount computer server or something like it could work great. Main problem there is coming up with the 12V supply (think: transformer you don't need anymore, junk bin job), though some are 120V, so try to find a used one at an electronics surplus style joint.
Check ebay for squirrel cage blowers. Try to find something reasonable.... For this application, IMO, it should be a larger diameter lower RPM job to reduce the noise.
