blown fuses in brand new lopi agp insert
mmj
88
middletown, ny
Recently had a lopi agp installed. It worked for a few hours and the fuse blew. Service man came out and changed the fuse, and the second fuse blew within hours. Awaiting the service man to come back out. Anyone else having the same problem with the fuses blowing on this particular unit?
i
Problem solved. When unit was packed in the factory 2 of the main wires(red) in the circuit panel were jammed tightly against some of the steel components which caused the insulation to rub off. Service tech fixed it with electrical tape, and it has been working ever since.
Are they going to replace the harness with a new one or just hope the tape stay's put?
I'd make another call and thank you dealer for getting you running temporarily and ask about a proper fix.
