My stove pipe often makes a boom sound on start up in the morning. It didn't do it last year (1st year of burning with this fireplace). It is an Enerzone 2.5 ZC.
I get similar sounds once in a while. Upon inspection all seems to be good. I would recommend to take a look if your able. See the back side of the stove, inside, outside, and the pipe connection. Then the entire pipe if you can. Look for splits or loose joints. This type of noise is usually just regular expansion and contraction.
Sounds a little like a back puff . . . or mini back draft . . . when a smoldering fire finally gets enough oxygen or a high enough temp to suddenly ignite the combustible gases in the woodstove or flue.
I've had this happen to me once . . . and experienced the "whuff" and resulting smoke coming out of nooks and crannies I didn't even know I had . . . but it was my fault . . . I had a bunch of coals and I just tossed on a bunch of cardboard and shut the door and didn't adjust the air control . . . cardboard smoldered for some time before finally bursting into flame.
If this happens often . . . could it be that you've changed in the way you do your reloads -- perhaps keeping the door shut or not opening the air as long . . . just thinking.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
