Broken Glass on Freedom Bay
drewjube
7
Hi All, I have a 4-year-old Lopi Freedom Bay insert that I purchased new. I have never overfired it and have otherwise used it in a consistently safe manner. However, this morning, after loading and starting a fire, the glass front cleanly cracked down the middle and split the glass into two pieces, one of which fell out. Any ideas what might cause that to happen?
Most of the time it is from shutting the door with a piece of wood up against the glass, the other times are from a split rolling into the window.
In your case the way you describe it, it could have been a screw was tightened down a bit too much and in time it just wore out the glass till it cracked or you had an imperfection in the glass.
Call your local glass places, I have noticed most of them will stock some neo/pyro ceram glass, take the glass with you so they can get exact measurements.
Thanks for the great advice. I found a glass place that says they can replace it if I take the door down.
